Greg1707
- Alexandria, VA
- Business owner Electrical contractor
The November issue of EC&M has an article on changes in the 2023 NEC. There are a number of changes regarding GFCI protection. The changes are mostly expansion of areas that require GFCI. The article states that GFCI requirements have been in the code for over 30 years.
Every code cycle has many changes in this area. The wording is changed, additional areas required. Kitchen countertops are required and then changed to within six feet of water and then changed back. For over thirty years this has been headed toward GFCI protection in almost all areas.
Meanwhile, the article does not mention any changes in AFCI. Both AFCI and GFCI provide protection for property and personnel. It seems AFCI has quickly moved to cover most areas in residential while GFCI is continually revised and crawls toward universal protection.
Any insight into why GFCI protection is always churning and creeping and AFCI has been quickly adopted?
