GFCI and Megger
Davebones
Have some panels with Siemens 20 amp type BF120 GFCI breakers . Before we power these panels up for the first time I want to Megger the panel buss . The instructions says to REMOVE the circuit breaker . Would I not be ok if the breaker is in the OFF position ? The megger voltage will be 500v . Don't want to assume anything . You know what can sometimes happen when you assume something .....
If the instructions say remove the circuit breaker, then do it.
