- Illinois
- retired electrician
only if they were installed under the 2008 or later codeSo all those receptacles 20 feet up in the ceiling of my garage that my high bay lights are plugged into require GFCI protection?
The receptacle's are much older than that. Although the breaker panel is much neweronly if they were installed under the 2008 or later code
No, I installed the GFCI on the wall, under the switch.Is the GFCI receptacle at 12' AFF? If so that's not readily accessible.
As I understand it, the code requires GFCI for every outlet in a garage, because it might be used for outside work. Even a DIY might unplug power to a garage opener.
Only if you were to build it now.So all those receptacles 20 feet up in the ceiling of my garage that my high bay lights are plugged into require GFCI protection?
Or replace a device.Only if you were to build it now.
