Hello folks,
I'm currently deployed in Southwest Asia. We have approx 4,000 window AC units that run contantly. Fequently, when high humidity (80+%) builds up at night (mainly), we have up to a dozen of these critters catch on fire.
It is believed that condensation drips on the motor/condensor and sparks the short/fire or a dirty filter/clogged drain hole that build water in the drain pan. We have a lot of blowing sand out here. Last year, nearly all breakers (4,000+) were exchanged with GFCI breakers to help prevent this problem (AFCI at that time did not fit our panels).
This season, we have continued to these fires, but I think there is a misconception of either how the fires start or the purpose/benefits of the GFCI breakers. Each window unit is on it's on circuit. Aside from the fires, we have nuisance tripping contantly in the high humidity/build up of water in the pans.
Since I not an expert on AFCI/GFCI protection, my question is: "is it a waste of $$ to purchase GFCI breaker or RCD/GFCI outlets in hopes of preventing a fire." While the breakers have a 30mA setting, will a short in the motor cause in imbalance that an GFCI/RCD will detect or will the just the short just create a high return amperage that will eventually be caught by the circuit breaker portion of the device (20A)?
Thanks for any advice/lessons
Richard
SouthWest Asia
Richard
SouthWest Asia
