I had a question ask of me if a GFCI is required at those tub where they dump the ice at a bar. No running water just tub with ice. Receptacle with in 6 ' of tub.
I'd say yes because the ice melts and you have a tub of water or a tub of ice water.
I agree.This is not a sink.
A bowl, bucket, dish, glass, cup of water is not a sink. Neither is a fish tank, or anything else that possibly might hold water.
The blender in the bar can hold water as well but is not a sink.
If you want GFCI protection in the vicinity where any of these items normally are placed but is not otherwise required in 210.8, there is nothing says you can't provide that protection.
The thing that increases shock hazard isn't water alone, it is proximity to grounded objects and is further complicated when there is also a presence of water. If this is a non metallic tub on a non conductive counter with a non conductive floor - the risks of it being an electrical hazard are not that high. An actual plumbed in sink has water lines and drain lines that even with the absence of other grounded objects being nearby may still give some current path to ground.
I just read 210 and I don't see where it's exempt.
Sink is not defined in the NEC.
I would say that if this ice dump tub has a drain plumbed into the building DWV system, it is a sink, even without running water.
Cheers, Wayne
I'm going to appeal to the definition at http://www.merriam-webster.com/dictionary/sink which reads: "a stationary basin connected with a drain and usually a water supply for washing and drainage". That definition includes a ice dump tub with a plumbed drain. It doesn't include a washing machine, as the basin isn't stationary.A washing machine is plumbed into both supply and waste, it also holds water.
Is it a sink?
The basket inside of a tub is not stationary on a typical washing machine but the tub is relatively stationary - only has limited movement on a shock absorbing suspension system.I'm going to appeal to the definition at http://www.merriam-webster.com/dictionary/sink which reads: "a stationary basin connected with a drain and usually a water supply for washing and drainage". That definition includes a ice dump tub with a plumbed drain. It doesn't include a washing machine, as the basin isn't stationary.
Cheers, Wayne
Cheers, Wayne
I didn't know that commercial ice machines sometimes get plumbed into the DWV system, thanks. Anyway, you've pointed out the failings of that definition, I agree.So a dishwasher is a sink. Got it.
A commercial ice machine is a sink. Got that too.
Is it a sink?
Is it a washer? Is it a sink? Yes, it's a Samsung!
