JFletcher
- Williamsburg, VA
VD and damaged conductors seem out then - What make/model is the spa? Even tho it's new, you may want to go thru the control panel and make sure all the connections are tight. Any chance the control panel or disconnect are getting moisture/water on them? Also, the last one we did came with about 40 pages of electrical installation instructions, apparently for every model that mfg made - does it require a neutral? Tho remote, perhaps one of the spa components has gone bad already.
The 9 days between failures - did the HO run the spa at any point between replacing the first breaker and having the second, unresetable trip?
eta: found this on a spa site:
"Some hot tubs, such as certain models of Hot Spring and Caldera spas (Watkins Manufacturing), require a special subpanel disconnect containing two separate GFCI breakers: one for the heater, and a second for the pump and other components..."
