websary
- Richmond, VA
- Refrigeration Engineer
Hi,
Any help with this question is hugely appreciated! I work for a commercial refrigeration company, and we have a customer who is saying that their codes require the use of a GFCI breaker on the circuit that will power our units. These unit will consist of a few 208V single phase compressors and a few low wattage 120V fan motors. The units are refrigerated display cases in a grocery store. They have some water inside of the case due to the melting of frost on the coil when the unit goes through a defrost, but it is separated from the electrical and I've never heard of this requirement. Two questions:
1. Does anyone know if NEC requires GFCI in this application? Does this seem like a reasonable code requirement? The location is Seattle, WA.
2. I am guessing that the having these compressors and motors on a GFCI breaker could cause nuisance trips, but I don't know that for sure. What are your thoughts?
Thanks!
Bill
Thanks!
Bill
