- Placerville, CA, USA
- Retired PV System Designer
Did you try a different load? I'm guessing that even a lamp would've done the same thing, and that the receptacle is using one or more wrong neutrals.
But I guess there's not a safety problem, is there? Except for the next electrician, if he interrupts a neutral's home run, that is.
If it is a neutral problem, at least we now know that it is between the first receptacle and the breaker terminals I'm the panel.
Tapatalk!
