- Connecticut
- Engineer
The receptacles are side by side. One is swiched. One is not. One is for lighting of a tv/mirror combo (very cool expensive tv I might add) and one if for the tv. When the tv is up on the wall the receptacles will NOT be accessable. There are other receptacle(s) in the room on different circuit(s) that satisfy the code. These are in addition to them.
That's what I had gathered from your posts.
I got it now. I was thinking one was for the vanity and the other for the tv/mirror. The TV GFCI is unswitched and the mirror GFCI is switched. Well it is a bad design in my eyes. If they are the same circuit then I would use a dead face gfci in line before the switches to the GFCI recep. in question. You could then eliminate the gfci's behind the tv/mirror.
If you use the GFI device that Dennis suggests, I would envision one duplex receptacle behind the mirror instead of two. Split wire the duplex receptacle so that one receptacle is switched and one is always powered. The GFI device would be installed in an accessible location.
