stew
- federal way,washington
what would cause a properly connected gfci to not trip on test? new unit and subbed another new one same candition. Any clues here?
I'm going to go out on a limb and guess that they all probably require a ground. Without a ground, they can't create a current imbalance between the neutral and the hot.Don't most "plug-in" GFCI testers require a ground connection?
Really?? I think that you meant to say "grounding conductor". If so you are correct that the GFCI will function correctly without an EGC, but in that case you can't use a plug-in tester to test it. See the diagram posted by Wayne.But again, a grounded conductor is not required for the GFI to work properly.
