GFCI NUISANCE TRIPPING?
grotor
Wisconsin
Appliance technician
Friend of mine asked me to replace bedroom receptacles in the house that he just bought. Everything was working fine for a few days and then GFCI installed in the basement by the previous owner had tripped and I wasn't able to reset it since. Of course, he blames me. I checked all wiring, receptacles, switches, etc., There were no obvious short circuits and visible damaged wiring. After I had bypassed GFCI (for testing purposes only). everything started to work fine. GFCI is 2-pole, 20 A. The breaker upstream is 30 A. The breaker upstream is labeled as "Basement/Kitchen", but it supplies power through the GFCI in question only to the basement lights and lights and receptacles (the ones that I replaced) in the bedrooms on the second floor. Kitchen and bathrooms have their own GFCIs that work fine.
The house wiring is very peculiar: mislabeled breakers, receptacles a few feet from each other are connected to different breakers, the wires in one receptacle look ancient, the wiring in the receptacle next to it look new, etc.,
What should I do at this point: to replace GFCI and see what happens or to tell my friend to call an electrician
Curt Swartz is correct.
We are obligated to protect the forum owner from liability, by refusing to offer advice that may harm untrained persons.
The moderators are sleeping on this one.
Locked post. Not sure how it got approved. To the OP, even a simple task like replacing receptacles can be a code violation, were those receptacles TR and AFCI as required by 2014 NEC? In reading the post I noted some concerning facts that you overlooked. Now an electrician needs to sort this out.
