I'm going to be changing a whole house with 3-prong receps using gfci breakers.
Where can I get a bunch of these stickers? Need probably close to 30 or so.
Thanks!
it would be better & safer to use a EGC barbed plastic pin blank to keep 3pin cap cords out by default. this invokes a clear physical warning that something is off when attempting to insert a 3pin cord.
anything done to a faceplate is technically just silly. a finepoint sharpie would be better than a sticker. and i dont even see the point of the "gfci protected" part. std new wire does not require such label. the thing with holes in it either is-or-is-not gfci protected, etc. they only recall what you "mumble" to them for the 1st ~20sec after you verbally tell them "these outlets here are gfci protected, and the trip-test/reset is over here"......
one of these should do the trick
Putting those in the ground slot? Really? Dumb idea.
ask the question the other way. what is the point of the device having a 3pin cap cord ??? it was put there for a reason, so why then do you welcome it to be used in a recept that has no egc ??? Do you think any avg joe who bought a countertop device that has a 3pin cord has any idea what the sticker means? no is the answer. much safer to keep nema 1's on 2wire ckts, but install gfi ocpd !That defeats the whole point of using GFCIs as a means to plug in 3 wire appliances on two wire circuits.
Thanks!
hold up.
so the logic i have heard this far is:
1) allow 3pin cap cords in
2) the stickers tell people "no gnd, gfci enabled"
3) they'll break off the gnd pin
4) they'll buy a cheater
1 - so what, that gnd pin does nothing in this case
2 - stickers fall off, and, std GFI'd downstream recepts don't need stickers telling people "this thing is GFI'd", so why do you do it here?
3 - so what, the receptacles offers no gnd anyways. if having the gnd pin was any meaningful safety feature of the device then why do we allow it to be used in a recept that has no gnd ??! in reality, a nema 1 is probably better !
4 - so what, its exactly what they do when they plug a 3pin cap into a 3pin recept that has no egc
blocking the gnd hole is a physical warning that no gnd is there. what the user does from there is up to them.
i gave the molly as example. recepts should come with a gnd pin block, similar to the molly but with a solid face, and when inserted it sits very flush to (just under) the recept face, so that folks cannot attempt to pry it out. maybe use orange as the color as an indicator of "this recept has no ground".
what does it matter. why not ask, are there any other items like it that prevent plugging something in, are those UL listed?Are those listed ground hole plugs?
If you block the ground pin hole - I'd bet most non electricians don't think hard at all about either finding a cheater or breaking the grounding pin off the cord - they have been doing it or seen it done for so long it they think it is the right thing to do.
Lots of things, caulking, cement, drywall compound, glues or epoxies, are all ones that may be even easier and more permanent in nature. Seems silly to plug the hole to me even if there is no EGC present, users will find a way to plug in what they want to plug in as a general rule. Chances are the item will work without an EGC and they have a false sense of security that nothing is wrong with that because their plugged in item does operate.what does it matter. why not ask, are there any other items like it that prevent plugging something in, and, are not UL listed?
i agree with you, but the logic was that the installer would inform the user of what the stickers meant. in my view, better to plug the hole and inform the user "see this orange plug, its an indicator that this receptacle has no ground and will not accept a 3prong plug. but i did replace the breaker with a dual function one to protect you from shocks". from there, if they choose a cheater or break the pin off their cord, thats up to them.
in order of preference (in my view)
1) use nema 1's on 2wire ckts, install dual function breaker (or extend a 3wire gfci to nema 1's, etc)
2) install the nema 5, plug the gnd hole, install dual function breaker (or extend a 3wire gfci to nema 1's, etc)
3) do #2 but also inform user that if needed, use cheater on this recept, do not break off the gnd pin from cords
hold up.
All that's really needed is a few ground rods. Wouldn't you agree?hold up.
Just buy a handful (maybe 5) of GFCI receptacles for use on other projects later and take the stickers out of the boxes.
I noticed you didn't mention AFCI protection for the replacement receptacles.
THAT receptacle may not have a ground, but others will. Cutting off the ground pin of an extension cord or appliance cord is stupid dangerous, and your reply is "so what"? :?:?:?. .
Per an earlier thread, I think the OP intends to use DF (AFCI/GFCI) breakers instead of DFCI recs to comply.
Yeah, in effect this ridiculous idea creates another danger- If/when the mutilated equipment were to be removed from gfci and plugged into to a standard 5-15 w/an egc, there is now a potential hazard which would not exist had the egc pin not already been cutoff to fit into Fionas altered receptacle- until the altered plug is replaced, the important egc connection is lost.
This whole idea shouldn't even be considered- putting plastic inserts into 5-15 recs is a blatant violation of 110.3(B)- have any of the device manufacturers ever ok'd it?:happyno:
