blacknumber4
I recently. wired a spa that is a single phase 3 wire spa there is no location for the neutral to land on the spa. How do i GFCI protect it? The spa only works when connected to a standard 2 pole breaker if I hook it up to a 2 pole GFCI breaker, it trips. There is no lighting on this spa so I do not see the reason for a neutral however the GFCI breaker needs neutral to work correctly. Is it ok to have the spa connected to a standard breaker at this point
