Good afternoon,
I have located a few topics on this forum relating to GFCI requirements for electric water coolers, but my question is in regards to the definition of readily accessible for the GFCI outlet serving the electric water cooler. If the GFCI receptacle is installed on the underside of the electric water cooler and does not require removing any plates to access the outlet, is it considered readily accessible, even though you have to stoop down to access it?
Article 100 Definition: (Readily Accessible). Capable of being reached quickly for operation, renewal, or inspections without requiring those to whom ready access is requisite to actions such as to use tools, climb over or remove obstacles, or to resort to portable ladders, and so forth.
This definition makes me think it is readily accessible as the references note mostly "going up"(ladders, climb), but would you argue that stooping down and reaching is also not considered accessible?
Forum Related Posts: http://forums.mikeholt.com/showthread.php?t=168937 , http://forums.mikeholt.com/showthread.php?t=164460
