north star
- inside Area 51
tw1156,
In reading your OP, I'm thinking that you [ may ]
be mixing apples & oranges with your question.
If you are asking if the Water Cooler, GFCI required
receptacle is "readily accessible" according to the
NEC, then I would probably say "Yes !"..........If, on
the other hand, you are asking if the owner, or
others restricted to a wheelchair, could access the
receptacle underneath the Water Cooler, according
to the `10 ADA Standards for Accessible Design, I
would say probably not.
Refer to Section 308.2.1, in the `10 A.D.A.S.A.D.
tw1156,
