I am dealing with an inspector that has a much different interpretation of readily accessible. The inspector is requiring a GFI device for bathrooms on each floor of the house where the bathroom is located. His reason is that he does not believe a GFI breaker at the panel for example is readily accessible if the panel is on a different floor as the bathroom.
Same is true with the dishwasher and disposal. He is making us install a GFI receptacle under the sink for both in order to make this readily accessible to the disposal and dishwasher.
We cannot install dual function arc/GFI breakers for small appliance circuits because the GFI device at the panel is not readily accessible to the kitchen.
The code also requires Arc fault devices to be readily accessible. They are all normally installed at the panel.
Furthermore if the disposal is hardwired does it need to be GFI protected? I do realize it has to be arc fault protected.
Any thoughts?
Any thoughts?
