ramsy
NoFixNoPay Electric
- LA basin, CA
- Service Electrician 2020 NEC
Thanks for clarifying that. Now, what about these code sections below. I'm not sure if they reference that definition in such a way that enforces a 4-6mA requirement?iwire said:You can not 'enforce' a definition, you enforce a code section that may reference a definition.
2002 NEC 552.60(A)(4) said:Receptacles requiring GFCI protection shall be tested for correct function by the use of a GFCI testing device.
NEC 680.23(3) said:GFCI's shall be installed ..so that there is no shock hazard ..in a conductive path ..to ground
