Buck Parrish
- NC & IN
Also if you decide to run a #12 grd wire instead. You can run it right up the wall, exposed.
I am pretty sure this is correct.
OK, so everyone has made it quite clear on what a GFCI does, and what to do when you replace a non-grounding receptacle with a GFI, etc...
Can I ask you what it was about lightning that you thought GFCI protected against? You've already shown that you believe it's OK to ask questions, and I totally agree, which is why I'm asking this one. Send me a private message if you don't feel like posting it here.
Current flowing through my body instead of the neutral will trip the GFCI and save my life?I think maybe I worded this question wrong. I realize how a gfci works. What I dont realize is what you are achieving when replacing a 2 wire outlet with a gfci besides not having to use a 2 wire plug adapter. You will still be without the ground.
Yup, that is exactly what happens.
IMO, its a poorman's fix to install a GFI with no equiptment ground. The right way is to just rewire the outlet.
It's still effective for line-to-neutral (I know, I know) surges.Just don't expect any good surge protection when using one of those plug-in surge strips in your non-grounded downstream outlets.
