We have a lab which uses small environmental chambers to test circuit boards. A typcial supply for these chambers use 40amp receptacles which are run under a raised floor. Our maintenance guys also ran the 40psi water supply and drain lines under this floor as well. The receptacles are not sealed (intrinsically safe). Is GFCI protection required? Our maintenance manager says no. I think it is. Who is correct?
