There Are Going To Be 5 Outlets Installed In A Coffee Shop Inside A Shopping Center. This Shopping Center Has 19 Seperate Units With A Firewall Between Each Unit. This Particular Unit Will Be A Coffee/sandwich Shop As I Mentioned Above. It Will Have A Drop Ceiling And Sheet Rock Walls. My Question Is Do I Need To Provide Gfci Breaker Or Receptical To These Outlets That Will Be In The Dinning Area .the Floor Will Be Painted Or A Type Of Acid Stain Finish. Is This Considered A Finished Floor Or Not?the Inspector Has Not Said Anything I Am Just Trying To Cover All Bases.
