Electrical and Safety Professionals have told me that the test button on GFCI receptacles is a test of the mechanical mechanism "only" and does not actually cause a ground fault. I'm also told that "portable GFCI /circuit testers" actually cause a ground fault and these devices should be used by inspectors to confirm the proper operation of a GFCI as well as proper wiring. Would appreciate clarification on this important issue by you folks in the field.
