Volta
- Columbus, Ohio
. . . The test resistor has to be designed so that at low line voltage the current will exceed at least the high spec limit of the GFCI. Looks like the resistance choice is good.
Also note there is an inverse time characteristic to the trip time vs current curve.
Ok. I have no trouble with that.
My initial post simply stated that AFAIK the only testing mechanism listed to test a GFCI device is the button on the front. Not an externally insertable resistance. The instructions I've seen included with the product don't seem to refer to any portable GFCI tester.
