GFCI will not reset
RusticKris,
A couple of people have questioned if you really have 120VAc to the receptacle in question. I missed where you stated the measured voltage? ( preferably under some load)
The GFCI does a test, to see if it can trip, when you push reset. The success of this test is dependent upon the line voltage level at the time.
( test is also depended on whether there is leakage on the load but you seem to have eliminated this since there is no downstream load)
I tested this function on a Leviton GFCI a while back. Results will vary some from device to device but in the one I tested anything below 108V started to get erratic.
At a 100-108V the reset button chattered a bit as it was reset , but did reset. At 95V it struggled to reset. Anything below 90V and it would fail completely.
Assuming you do measure a supply above 108V ( under load) does the unit chatter excessively as you attempt to reset it?
Your test results, on a separate line cord, will be helpful.
I generally use Leviton. I too have seen some chatter on reset. Will check actual voltage next time.
I was thinking more in the line of a broken/loose branch circuit neutral.
People rarely think about the service being a MWBC, but you're right, it is.
The service is not a multiwire branch circuit, it is just a multiwire circuit, same with feeders. Unless you have a two wire service or feeder, or an ungrounded or corner grounded delta system.
MWC, but you knew what I meant.:slaphead:
It is a branch off of the utility service though.:p
Got to thinking and remembered similiar problem, changed out rarely used GFCI recep, 2 weeks later new one failed.
Turned out to be full of little bitty ants, probably what got the first one.
Happened to me too in a mobile home kitchen. Once the ants had been killed off and the ones inside the GFCI had dried up it started working again, but I replaced it anyway. :)
