GFCI
sndbodkin
Blackfoot, Id
Recently I was approached by an electrical inspector on a job site where we had installed 50 amp 3ph 240 vac receptacles in a wet location. The inspector told me we would have to protect the receptacles with GFCI breakers as per 210.8B. This is a 240 volt 3ph delta service. The spec. sheet of the Square D 3 phase breakers available states 208/120 vac. Where the high leg is 240 volts to ground, does this code reference excuse the GFCI requirement in this location?
IMHO it does not excuse GFCI rule non-compliance. If breakers are not available look for something else.
So far the only 3P 50A GFCI I have found is that SQ D and it clearly says 120/208V.
Gonna be a bit rough when 2017 NEC kicks inless manufacturers are gearing up.
IMO, the NFPA went way overboard on this.
2017 NFPA-70 210.8(B) excludes your high-leg 240v to gound:
"and threephase receptacles rated 150 volts to ground or less"
Thank you for all your input on this. This change will be a major impact on our customer. I think a a lot of the changes in the NEC are driven by manufacture lobbyist trying to increase company revenues instead of safety and common sense.
There is a lot of that, I agree, but I think a big part of it is at the end of the session the cmp members want to go home feeling like they've done something to make the world a better place and saying, "We've done enough already, let's hold off on adding more regulations" doesn't give them that satisfaction.
I think you mean 208v to ground.
240v 3-phase Delta is 240v to ground not 208, much less 150.
GFCI protection > 150v to Ground not required under this section.
2017 210.8(B)
B) Other Than Dwelling Units. All single-phase receptacles rated 150 volts to ground or less, 50 amperes or less and three-phase receptacles rated 150 volts to ground or less, 100 amperes or less installed in the following locations shall have ground-fault circuit-interrupter protection for personnel.
