sndbodkin
- Blackfoot, Id
Recently I was approached by an electrical inspector on a job site where we had installed 50 amp 3ph 240 vac receptacles in a wet location. The inspector told me we would have to protect the receptacles with GFCI breakers as per 210.8B. This is a 240 volt 3ph delta service. The spec. sheet of the Square D 3 phase breakers available states 208/120 vac. Where the high leg is 240 volts to ground, does this code reference excuse the GFCI requirement in this location?
