look in 210-8(B)
210.8(B) refers to 15 and 20 amp 125 volt circuits........not 30 amp or larger 220 volt. Am I missing something?
No, but not for the reasons the electrician stated.
For the most part the NEC only requires GFCI protection of 120 volt 15 and 20 amp receptacles. See 210.8
So let me get this right........ 15 and 20 amp circuits with in 6' of a sink require GFCI protection.
More amps/volts within 6" of a sink do not.
Dosent make sense.
The 15 and 20 amp receptacles are the ones into which your common work tools will be plugged. Those are the ones that get the most use, and the most abuse, and are more likely to have internal problems. As Bob said, the statistics show that there is a real value in protecting those receptacles.So let me get this right........ 15 and 20 amp circuits with in 6' of a sink require GFCI protection. More amps/volts within 6" of a sink do not. Doesn't make sense.
