kwired
Electron manager
- NE Nebraska
- EC
Depends where it is separated and what other alternate paths are available. If a low enough alternate path is available you may not even know the neutral is open, because in a way it is not open.You are correct of course; if the neutral were to get separated from the POCO neutral and still be connected to ground the branch voltages would still wander. Usually when the neutral gets disconnected it gets separated from both the POCO neutral and the ground, though it is the separation from POCO neutral that causes the problem. I don't know what I was thinking.
