rick loconti
can't find in nec how many gfci receptacles allowed downstream of first one, any help?
Are you refferring to placing GFCI protected outlets downstream from the GFCI outlet or breaker or are you reffering to placing several GFCI outlets daisy chained together?
If the latter this is not a wise installation as false tripping is bound to happen and or not knowing which GFCI has faulted.
As many as you like however you may want to keep the total distance under control. I have heard that long distance from the GFCI to the last outlet may cause some issuescan't find in nec how many gfci receptacles allowed downstream of first one, any help?
What makes you say this?
anytime I have seen multiple GFCI's downstream( protected by a up stream GFCI ) I have had customer complaints of nuisance tripping in such a installation not done by me. Besides why would you spend for a GFCI and on the load side of this add more GFCI's. If you have a Ground Fault it may trip other GFCI's in the daisy chain then you have to look around for the GFCI that is tripped. I don't know many customers that are happy to pay a service call to push a button.
I never have multiple GFCI's protected by upstream GFCI's . In my world it's just bad practice , a waste of good money, and a complaint waiting to happen.
i run into this kind of thing alot, theres nothing wrong with putting gfci outlets down stream from a gfci already protecting the circuit. BUT why would you!! when one trips by fault or a good thunder clap.its going to cost the owner a service call to repair, the down stream outlets are dead do to any of up stream gfci tripping, and they wont reset.So i think its one gfci for all , or each location gets a gfci wired on line side, BUT again why waste the money on many gfci outlets when one will do-IMHO
So true! I once spent a frustrating hour tracing a mysterious circuit outage, and eventually found three GFCI receptacles in line on a single circuit: one in the living room, one in the hallway, and one in a bedroom.i run into this kind of thing alot, theres nothing wrong with putting gfci outlets down stream from a gfci already protecting the circuit. BUT why would you!!
When you wire a 4-5 bathroom house, one bath circuit,I hope that there are no girls with hair dryers living in this house :grin:
Why? If you're under the '08 NEC, the outlet for the garage door opener is required to be GFCI protected in dwelling units.we have a local inspector not allowing a grounded receptacle downstream of a gfci receptacle to protect a garage door opener
When you wire a 4-5 bathroom house, one bath circuit, Do you put a GFI in each bathroom? Or only in the first one and load wire the rest?
