G
Guest
Guest
Re: GFI Circuit
What if GFCI's were "auto-setting"? When you first plug in a device there would be an indicator on the device telling the GFCI what level to set the fault threshold.
It would be like in cameras that auto-sense the ISA (speed) of the film cartridge. When you plug in the device it would tell the GFCI "I'm a two" and the fault threshold would be set a seven instead of five. That would minimize nuisance tripping.
Or, maybe GFCI should be just be integral to every device like they are on hair dryers, etc.
Just thinking out loud here. You've probably already heard it one hundred times. Thanks for listening.
[ September 20, 2003, 08:50 PM: Message edited by: awwt ]
OK, Pierre now you've got me thinking and this is probably not a novel idea. It sounds like some devices need a "tare" leakage. Like computers. If they leak "1" and the normal threshold is "5", then the fault threshold should be turned up to "6" for computers? Within reason it would be helpful to turn up the fault threshold. Of course there has to be a fault threshold ceiling-- at the point where a device becomes absolutely unsafe.Originally posted by pierre:
<snip>If the GFCI is tripping, something is wrong!!! <snip>
