george t. everett
- New York
I see a lot of installations where the feeder for a pool panel is fed from a GFI breaker. The pumps & light are connected to standard breakers. 680.23(A)(3) states that the gfci for the pool light has to be installed in the branch circuit supplying the light. I believe that this installation is not code compliant. If a gfci breaker were install in this panel for the pool light, would this make it code compliant ?
