I'd check the panelboard and see if there are GFCI breakers protecting the above circuits. Using GFCI breakers is often a better way to go because they are more reliable than GFCI receptacles, and one breaker can protect an entire circuit without having to worry about wiring a circuit so that the GFCI receptacle is upstream from the others.Originally posted by logie:
Hi we are in the process of having our house built and I noticed that none of the above areas have and GFI outlets.
I know that GFI circuits can share from another, but there is not one GFI outlet at all.
I thought they had to do this to be up to code for (Louisiana)
The National Electrical Code is a SAFETY code and is the MINIMUM requirement for SAFE electrical installations.All of the areas need GFCI's.
