I recently upgraded the electric in a bathroom in a recently acquired rental property, by changing the old 3-prong outlet to a GFI. This was installed in a 3 gang box. The other two compartments were for switches that controlled the two bathroom lights (one over the sink, and one over the tub). In any case, in an effort to GFI protect the lights, I connected their feeds together and pigtailed that to the LOAD side of the GFI. The incoming hot also supplies other fixtures (hall and bedroom lights), so I ran a pigtail from that incoming hot to the LINE side of the GFI, and did the same with the neutrals. I should note that there is only ONE circuit in this box.
After hooking it up this way, I tested the GFI, and the bathroom lights, and everything worked correctly.
However, the next day, I switched on the hall light (3-way switch), and the bathroom GFI popped. I reset it, and then turned on the bedroom light (not a 3 way switch), and the GFI popped again. Obviously, the GFI is sensing an unbalance, but I really don't understand why.
I went back into the 3 gang box, and rewired it such that the GFI was the end of the run, and the switches were removed from the LOAD side of the GFI, and simply wired to the incoming hot. After that, everything works fine.
I am simply trying to figure out why this is happening. Can you NOT have a switched luminaire downstream from a GFI? Why doesn't this happen if I plug a light into a downstream outlet in the bedroom, and then turn on that light switch? Again, I do not have a problem, I am simply trying to educate myself, to get a better understanding.
Thanks in advance.
Jeff
Thanks in advance.
Jeff
