- Placerville, CA, USA
- Retired PV System Designer
So, in some locations, this double GFCI is actually mandatory; so they had better be compatible.
Tapatalk!
Tapatalk!
Does the "pop machine" trip the GFCI as soon as you plug it in, or does it work ok for a while and then trip it?
When you say "shop" is a GFI required? If you ran the wire can you just put a single receptacle and be done with it.
Runs for a while. Not a set time or anything.
Well, interesting enough that it runs for while then trips GFCI. You may have a faulty run capacitor on the compressor or some other internal problem that is getting by the cord mounted gfi ( by the way does anybody know if cord mounted gfi's are 30ma or 5ma fault protection).
