I have encountered a problem with some GFCI's in a customers home. I have seperated line and load and installed three new GFI receptacles, I've even pigtailed all the hots together to the line side and all the neutrials to the line neutral side and the GFI will still not trip out when testing hot to ground. The test and reset buttons work but the device does not trip out hot to ground. The kicker is that that is not the only GFI receptacle in the home doing this. I thought that maybe some how the neutrals of two different circuits were some how tied together. When testing for voltage I have a good hot, neutral, and ground. I hope someone may have some advice pertaining to this. I've been an electrician for a long time and have never seen anything like this, but maybe I am not seeing something and need a fresh set of eyes!!
