Bullcub145
- Savanna, IL
Because...
1. The code does not require it.
2. Why should the electrician have to spend extra time and money to install something that is not code required? ... and is not a safety issue.
3. If done wisely, the OP has an opportunity to educate the inspector as to the correct code requirements.
So, instead of going above and beyond, lets just waste more time and money by doing just the minimum and argueing about it. Seems to me the whole thing would have been settled easier by installing the GFCI breaker. If the fan/light is UL listed to be GFI protected when above the bath/shower than it has to be protected, otherwise it is no longer UL listed for that location. Plus, when argueing point number two on your list. In the long run it isnt wasting any time to install a breaker, and the money is well worth the cost for the added safety.
