charlie b said:The code says to install "two or more SA circuits," and then it says they shall have "no other outlets." So powering the range hood from one of the three SA circuits would still not be allowed.
RUWIREDRITE said:Laguilar,
I would consider, though not required to run a seperate circuit for that hood installation. The reason being the 2008 code may require it anyway in the future, and with the way the consumer is thinking lately, that hood will wind up turning into a micro-hood someday.
Exception No. 2: Receptacles installed to provide power for supplemental equipment and lighting on gas-fired ranges, ovens, or counter-mounted cooking units.
gary said:The 2005 code already requires a separate circuit if the hood is to be connected with a flexible cord. See 422.16(A)(4).
LAGUILAR said:Help Me understand The Exception,on the bottom Of The paragraph.At 2002 Nec 210.52 (b)2 Execpt.#2
My interpretation of the question was that the "kitchen hood" was a separate component, not an integral part of the range. That is how it is in my house, so I suppose that is why I had that configuration in mind.LAGUILAR said:Charlie, Help Me understand The Exception,on the bottom Of The paragraph.At 2002 Nec 210.52 (b)2 Execpt.#2
