GerryB
- woodbridge, ct. USA
This is an existing in ground pool with an existing 240 volt filter, new last year, supposedly energy efficient with a digital timer, etc. I say supposedly because according to the HO it's supposed to run 23 hrs a day. A gas heater was just added that I was called to wire. It comes factory for 240v, can be wired 120v. The pool guy said I could tap off the 240 line for the filter, which I did. The problem is everything runs for a few days and at some point trips. He wanted me to change the breaker, I did, same thing. Every time I've been there everything was running, filter on, water toasty. The pool guy said the same thing, actually the HO is the only one who saw the breaker tripped and reset it. I don't question her though. My question is today the pool guy called me and said I didn't bond it with a #8 from the filter to the heater, so I'll be doing that tomorrow. My #12 ground is on the lug in the heater and spliced to the ground in the switch for the filter where I also picked up my feed. Do you think not having the 4 feet of #8 bond wire from the filter to the heater is causing the breaker to trip only every 3 or 4 days.
The pool guy definitely wants to put it on me, which is fine, the customer is very cool. But my experience with GFI's is they trip immediately or on some particular cycle like with a hot tub.
