Re: GFI
jhc,
Here's something else to look at.
None of the components in an Electrical System is perfect. They all have a certain amount of inherrant 'leakage'. Manufacturing specs are such that the 'leakage' is kept below a certain level, but if you add enough 'leaky' items together you will, at some point, have enough to cause tripping of a GFCI.
So, a fine point, but there must be some practical limit to the quantity of components that can be downstream of a GFCI. But there are too many variables to put any numbers to it.
To echo the others, only one GFCI is needed for the circuit if everything is connected downstream.
Bill
