Restricting the intake is not a good way to regulate the flow of any pump, be it centrifugal or positive displacement.  A centrifugal pump uses centrifugal force to move liquid and is sized (selected) to pump a certain amount of liquid at a certain volume and against a certain back pressure. The selection process includes fluid viscosity, desired flow rate, and calculated back (head) presure that will oppose the flow. At maximum flow, the pump will require maximum horsepower. If the flow is restricted (closing valve, increased head pressure, increased piping loss such as elbows and valves) the flow and the horsepower required will decrease simultaneously. If the discharge valve is closed completely, the horsepower (electrical current if a electric pump) will decrease dramatically although the pump pressure will climb to it's maximum amount (cut-off pressure). As the valve is slowly opened, the flow rate and required power will increase simultaneously until it reaches it's (most efficient) maximum flow.  Any further decrease in back pressure will cause greater flow at decreased efficiency. Restricting the intake will cause reduced flow but also cause cavitation (starved suction) in the impeller and result in noise and damage to the impeller and housing.
A positive displacement pump is just what it says. Flow rate is dependant upon  pump displacement, fluid viscosity, and power input. Any incease in pump speed will result in increased pressure, fluid flow and required input power. The power increase is dependant on the fluid weight of the increased flow and the resulting resistance to flow caused by pump and piping loss (increased resistance to flow). If you close the discharge valve on a positive displacement pump, the flow will decrease and the discharge pressure and required power will increase until the power source (motor) is overloaded or something breaks. To prevent this, most positive displacements pumps have a relief valve to allow excess fluid (pressure) to be diveted back to the intake (re-circulated).  Restricting the intake on a positive displacement pump can also cause pump damage.
I learned this by experience, so some of it may be questioned by any experts out there. I'm open for discussion and willing to learn (or teach).
steve
