You bring up a good point, and one that is subject to debate. The way I see the situation, the people who work inside the trailers are included in the category of "the public." I say that because (1) They are not especially trained to recognize electrical safety hazards, and (2) They are the ones most likely to be injured (or worse), in the event of a failure of any of the equipment within the trailer.Jomaul said:They wouldn't be required on recpt for use in the trailers, if the inside of a trailer is not accessible to the public.
zog said:Dont confuse a GFI and a GFCI.
petersonra said:I think the term used is "general public". I don't see how an employee of the carnival can be considered part of the "general public".
210.8(B)(4) says this about “outdoors in public spaces”:Jomaul said:Thats my point. This code article speaks to the outlet that the trailer is plugged into and not the outlets in the trailer.
The NEC does not say what it means by “the public.” Article 525 uses the phrase “general public,” and that phrase is not defined either.For the purposes of this section, a public space is defined as any space that is for use by, or is accessible to, the public.
That did not help. It did not settle the question of whether an employee of the concession stand is a member of the ?general public.?Pierre C Belarge said:Take a look at Art 525
