Flicker Index
- Pac NW
- Lights
These days, LED lamps with the LED elements sealed up inside an airtight glass bulb like below is quite common.
Apparently that is often due to manufacturing or design issues.
Plastic and glue materials used within can give off organic gases as they heat up and some of them will darken the LED elements.
If you experience a situation when you end up with a whole bunch of them turning super dim prematurely, crack open the glass on one of them. You can do it without damaging the internal LEDs by wrapping it in cloth and squeezing in vice until it cracks. If you smell nastiness or see LED elements scorched brown, that's a hint.
Break the glass off and let it operate for a few days in a safe location. (the elements will be live). If outgassing is the cause, the bulb will generally return to normal output and the brown scorching goes away after a few days of operation without the envelope. If that brought it up to normal output, then remaining bunch of lamps that turned dim likely also snuffed out in its own funk. If they're still within warranty period, warranty them all.
