The specs say the inverter output is 9.6 kW, so you had to dial that back to 7.7 kW because you only had a 40A feeder available?This setup is on a 40A detached garage circuit.
Pretty sure you are required to do that, all of the applicable NEC sections treat the inverter output current as a continuous current and require OCPD sizing of at least 125% of that current, unless you are using 100% rated OCPD (which don't exist at this rating). E.g. 2023 NEC 706.31(B)@wwhitney I did not. Consumption won't exceed the output rating.
Yes, on the link in post #2, at the bottom you have to select the second tab (internal to the web page rendering) to see the specs on that inverter.Looks interesting, so does the car just output DC and one of those boxes is a special inverter for the car DC?
Sorry for the dumb questions, you mean post #5?Yes, on the link in post #2, at the bottom you have to select the second tab (internal to the web page rendering) to see the specs on that inverter.
Cheers, Wayne
I wonder what the DC voltage / current on the input is?
Whats the output voltage spec? Can it connect to a single phase 208/120 panel?
Seems like it works on a wide range of vehicles.
Does it use the 'standard' (non tesla) SAE J1772 or whatever car plug used for AC charging and run DC backwards?
Another aside @Chamuit 's dog looks adorable.
Yes, 3, 5, one of those small primes. : - )Sorry for the dumb questions, you mean post #5?
Some googling turned up this page with various actual installation manuals and spec sheets:These 'specs' don't satisfy my curiosity:
Ok very interesting that there is no accepted standard, probably Tesla will make up one (or has) and everyone else will do something different. It looks like the GM EVSE/V2H makes the car appear as a DC battery to the inverter and the GM inverter looks to support variety other batteries that can talk to it over the RS-485 serial communications port not just a GM car, the specs say RS-485 and Modbus. Hopefully then it is just a matter of a manufacturer making a EVSE/ V2H 'charger' that is compatible with that RS-485 or modbus that the inverter uses and then any car can attach to it. It also looks like it supports a DC PV array.It will only works with specific GM vehicles. Ford’s only works with the Lightning. There is no V2H standard, so each manufacturer uses their own. The vehicle has to accept a handshake request from the equipment to engage contactors that direct the DC battery voltage to the CCS port. There is presently no adopted standard for that handshake.
The acronym 'V2H' is used when the vehicle has an on-board inverter that can be used in place of a generator. That's considerably easier to design as the inverter is put in the HVDC enclosure, with only current limited AC on the harness to the receptacle.
