I know that there are a lot of us that have a GM van with the side double doors instead of the sliding door.
I am having a problem with the hinges on the door on the left being very stiff. Seem that with the hinge exposed and facing into the wind all of the road dirt gets into the hinge and makes it very stiff.
I know all the vans where I work have had this problem. I know that at least one of them had the hinge rip off the welds to the body because of the repeated use while stiff.
I have sprayed the hinges with WD40 and white lithium with not so great results. Almost every van I see on the road with this setup has a very dirty area around the hinges from trying to lube them.
Is this common in other areas as it is around New England?
Is this a design flaw by GM? Exposed hinges, WHY?
When I asked about it at the dealers service counter, I got a blank look and no results.
Anyone have a good fix without taking the door off the hinges?
