tallgirl
- Glendale, WI
- Controls Systems firmware engineer
iwire said:You have no idea, really you don't.
See it is not just water, it is the chemicals, in some areas salt is still heavily used and where the roads run through wet lands it is some other chemical.
Yes, and what most of y'all are using -- WD-40 -- is a penetrating oil and degreaser. WD-40 is great stuff, but it is not a lubricant in the same sense that either lithium or moly grease is a lubricant. It's also not weather resistant the way heavier lubricants are, and lithium grease is not a dry lubricant the way molybdenum disulfide (the stuff in moly-based greases) is. Nor is lithium grease resistant to salts and other chemicals -- the stuff you're complaining about on the roads -- the way moly grease is.
What y'all are doing is degreasing your hinges and replacing the heavier oil products (grease) used to lubricate the hinges with what is basically mineral spirits and naptha (lighter fluid) in a spray can. You using a solvent as a lubricant, basically.
Read the links. They'll help explain why you want moly grease instead of lithium grease and why you definitely want to stop with the WD-40.
Just read the links, okay?
