Go-To ladder...
If a 4 ft ladder covers a lot of your needs to get taller you might want to consider buying a platform instead of a ladder. They are not a lot different cost-wise than a ladder and are more versatile although they do take up a little more room. Someone loan me once to paint some ceilings with. It was a whole lot simpler and safer than a step ladder would have been.
It look like this that was a different brand.
https://www.homedepot.com/p/Werner-...orm-with-225-lb-Load-Capacity-AP-20/100662616
Can't stand on it, it only has 2 rungs.
Top platform is for tools, so you don't have to bend over to get them.
The manufacturer’s instructions would seem to indicate otherwise. It is made to stand on.
OSHA also has jurisdiction during construction on job site's, over all elevated platforms and scaffolding.
Platforms are allowed with guard rails, and listed fall-protection lanyards, certified to support the deceleration of a 180 lb weight.
I'll admit my OSHA knowledge is no longer current, but this type of platform (not exceeding 32" tall) is (at least used to be) defined by OSHA as a step stool per 29 CFR 1926.1050(b). The platform requirements you mention would not apply if this is still true.
For not being current, I'd say you nailed that reference with an interesting list of definitions, especially this one:
Step stool (ladder type) means a self-supporting, foldable, portable ladder, nonadjustable in length, 32 inches or less in overall size, with flat steps and without a pail shelf, designed to be climbed on the ladder top cap as well as all steps. The side rails may continue above the top cap.
Full disclosure - I had to Google to find the reference.
It was not from memory.
But I was pretty sure that the definition existed from back in my plant Engineering days.
