This is in the design phase. I have 20.8 kV coming from the utility. The utility says the service point is on the load side of the metering CTs mounted on the utility pole. The utility is requiring the client to have their own dead-end drop pole. The load side of the CTs are connected to overhead conductors going to the dead-end drop pole. From there service conductors are routed underground to feed fused disconnects in switchgear.
Is it code compliant to mount a gang-operated air break switch on the dead-end drop pole, or does 230.82 make a GOAB switch a violation?
