gotta love maintenance men
frizbeedog said:
What's the ampacity of a piece of wire from a coat hanger? Saw that when I pulled one out of abox the other day.
wow - that is the making of a fire - that coat hanger will loook like a filiment I bet when current passes through it
peter d said:
That's why I can't stand those Allied fiberglass boxes.
Peter, if you look close, that appears to be the T&B bakerlite (Formerly Union Box) that you and I like so much. It does not look like an Allied.
And I have seen the T&B's break like that many times. They are the only box I use.
I like the "union box" for walls that will have a very thick finish material applied. They have the nails at the very back corners of the box, so you can leave them stick out up to a couple inches, if need be. You can also nail them on from behind, like sticking out of exterior sheathing or shear walls, which is more difficult to do with the typical blue zip box.
Of the very few broken union box ears that I've run across, I think I can safely say that 99% of them had the wrong size screw installed. A #8 screw in the #6 device screw hole will absolutely break it. The other 1% I think were abused between the ruff and finish by other trades.
Yeah, I think you're right about that now that I look closer.
We install a lot of receptacles in baseboard and a lot in backsplashes with 1.25" granite plus blueboard, so the ability to set the boxes further out is convenient for us, too.
The damaged boxes that I've come across are almost always from the board men with either a hatchet or a router.
Essentially, I agree with everything you said.:smile:
