enireh
- Canyon Lake,TX
why do we not separate the grd from the neutral at the main panel and at what point is it most important to separate them. for example if a main panel is two feet away from the meter that is ok to have neutral and grounds together but at what distance do they need to be separated or is it not a distance issue? I'll take my answer off the air thank you
Edit Post Reply With Quote
