weressl
Esteemed Member
A quick search of the forum didn't turn up any results...
Does anyone here use some kind of grease for the bases of outdoor floods to keep them from seizing up in the socket? If so, what kind do you use/recommend?
Some automotive lamps come with a little greese packet within and they instruct you to coat the contacts with it. My ususal curiousity got the best of me so I strated hunting for the enswer. It appears that they are trying to prevent contact oxidation, which makes sense, especially if you live up North with salted roads. Temperature is a problem of course on larger incandescent bulbs with more wattage. I've seen heat runs on Class I, Division 2 lamps certification tests where they stick 50-60 thermocouples all over the fixture to determine the hottest point on the fixture for T-rating an it was always at the lamp base. One number sticks in my mind is 177Centigrade, but I can't recall what type and wattage fixture that was.
Most lamp contacts are designed to perform a wiping action either when inserting or twisting and that action removes the oxide layer from the contact surface. As the lamp heats up the 'grease' flows all over the area and forms a barrier to the contact area, so corrosion can not start.
