sheldonrf
- Washington, DC, USA
I am designing a green roof, I have the roof setup as the following: (from the bottom up)
Concrete roof deck
Insulation layer (about 1" of styrofoam like material)
Waterproofing build up layer (about 6" thick)
Air Layer (1/2" thick)
Root barrier membrane (4mm thick or about 1/8")
Reservoir sheet (1 5/8" thick) - actually looks like some egg crate
Followed by either - gravel rock / pavers / "growth media" (I assume to be dirt) and grass all of these are in the general category of 3" deep
Here is my conundrum.... I am installing power throughout the roof area and I need to run conduits. My overall depth is generally about 12 inches. I can not run my conduits in the insulation layer as it will cause condensation issues on the slab in the space below (which is already at a VERY high humidity), the client understandably does not want roof penetrations all over the place for the multitudes of receptacles that I need to place everywhere. Would this application even be considered direct burial? There is no AHJ to go to and ask, I have to derive this through the NEC and tell them. I plan to install all schedule 80 PVC (but that can change). Any advice is greatly appreciated......
Concrete roof deck
